Foam removal from bed........
Old Mar 28, 2002 | 08:27 PM
Wilber15's Avatar
Wilber15
If it ain't broke.....change stuff till it is!
I have that foam stripping used to pad the topper for trucks on my bed. is there an easy way to take that off without stripping or scratching paint? I bought the truck with that molding on it, but no topper. I want to take the stuff off....any help would be great. I wanted to use a putty knife and scrape it off, but i'm affraid the paint will come too.
Old Mar 29, 2002 | 06:40 AM
karljay's Avatar
karljay
I'd try Goof Off. You can get it from Home Depot. I'd try lifting an edge and sqirting it under where it sticks to the truck.
If you peel it, it might take some paint with it and the Goof Off won't damage the paint unless you really soak it.
You might check for an adheisive remove while you at home depot.
Old Mar 29, 2002 | 08:31 PM
restorit's Avatar
restorit
