Sponsored by: Real Truck
super duty front calapers
Old Mar 7, 2009 | 11:25 AM
jmarsett's Avatar
jmarsett
My passenger side front caliper drags, Do I need to replace it or should I be look for another possible cause.
Old Mar 7, 2009 | 11:26 AM
rob188's Avatar
rob188
start with lubing the sliders
Old Mar 7, 2009 | 03:29 PM
bubbasz1's Avatar
bubbasz1
If it is the pins that are stuck it will require taking off the caliper mount and heating the pins to remove. I have found that installing a new set of pins last longer than lubing the old pins. BTW, I have always had to use the blue tip to loosen the pins, the propane torch doesn't have enough BTU's to do the job.
If the pins are free I would look at the caliper pistons and rubber seals around the piston, if one is tore and the piston is stuck you might as well get a couple of rebuilt calipers for her.
Old Mar 7, 2009 | 03:36 PM
jmarsett's Avatar
jmarsett
Thanks for the advice. Found the pins free. but one piston very stiff. New calaper on the way
