86 Bronco firewall cracking
Old Apr 10, 2002 | 07:44 PM
troopie's Avatar
troopie
My 86 Bronco 4.9L with manual transmission recently had a problem with the clutch not fully disengaging at times. It turns out that the firewall was flexing, I could see the reinforcing ring around the steering column on the firewall move when the clutch was depressed. I had been hearing cracking noises when I used the clutch before the movement started. We welded the ring to the firewall, and everything seems to work now. Has anyone seen this before? I understand there is a factory reinforcement kit or two for this problem.
Old Apr 11, 2002 | 09:02 AM
karljay's Avatar
karljay
I think someone posted a thread about this before, I think your right about the kit to fix this.
Old Apr 11, 2002 | 08:54 PM
Bob_VT's Avatar
Bob_VT
