72 speedometer question
Old Mar 7, 2009 | 07:44 AM
7278ford's Avatar
7278ford
Does anyone know how many revolutions of the speedometer cable on a 72 f100 it takes to register 1 mile? I need this info to calculate the correct speedo gear. Thanks in advance.
Old Mar 7, 2009 | 09:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford sez: 1) You need the axle ratio. 2) The type of transmission and 3) The tire size to calculate the correct speedometer DRIVE & DRIVEN gears.
When I know what those three are, I'll tell you what the correct gear is.
The way you are going about it, will be impossible to calculate.
Old Mar 7, 2009 | 10:11 AM
Bdox's Avatar
Bdox
Does the speedo work at all now?
Old Mar 7, 2009 | 10:40 AM
bmuhlbach's Avatar
bmuhlbach
I bought a kit from cj pony parts it has about 4 gears from 16 tooth to 21 tooth and adjusted it I believe 1 tooth is good for about 3-4 miles per hour my car was off about12-15 mph went from a 16 to 21 and it was right on.
Old Mar 7, 2009 | 11:56 AM
NumberDummy
Ford has available and most dealers stock: 16, 17, 18, 19, 20 and 21 tooth nylon driven gears.
The same ones have been used since 1960, the prices range from $2.00 to $3.50 each.
Old Mar 7, 2009 | 01:00 PM
7278ford's Avatar
7278ford
no not hooked up.
Axle ratio is I think 3.50:1 the transmission is a C6 but mine is 4wd so I have the NP205 t-case and my tire size is 33".
