need inner fender picture
Old Mar 6, 2009 | 09:54 PM
shack's Avatar
shack
Hey guys,
Anyone got a picture of the inner fender area where the hood hinges on a 73 highboy. Isn't this a spot that is bad to rust? I'm looking at a truck that looks like it might have an after market cover over that area. If I'm lucky, I will be driving it home soon!
Thanks, Joel
Old Mar 6, 2009 | 09:58 PM
fmc400's Avatar
fmc400
MSEE
Where exactly is the plate? Some trucks did have a reinforcing plate in that area to keep the hood from going through the windshield in a front-end collision, but I'm not sure of the years. I thought it was later years though; I don't think a 73 would have it unless it has been swapped over.
Old Mar 6, 2009 | 10:01 PM
shack's Avatar
shack
Thanks for the reply,
It's the area where the hood hinges bolt to the inner finders.
Regards, Joel
Old Mar 6, 2009 | 10:03 PM
Jermafenser's Avatar
Jermafenser
Does this cover go over the inner fenders and bolts go through it? If so, sounds like it was factory. Those were installed if you ordered one with the factory topper.
Old Mar 6, 2009 | 10:06 PM
shack's Avatar
shack
Yes it does! And it's galvanized.
Old Mar 6, 2009 | 10:19 PM
Jermafenser
Galvanized? The ones I've seen are black; may be different on earlier years...
Old Mar 6, 2009 | 10:46 PM
shack's Avatar
shack
I don't know, I sure would like to see a pic of the 73 model
Old Mar 7, 2009 | 01:21 AM
Bgasrickshaw's Avatar
Bgasrickshaw
I think some of mine are galvanized. I'll look and take a pic tomorrow.
Old Mar 7, 2009 | 02:11 PM
Bgasrickshaw
All of mine (12, picking lucky # 13 tomorrow) have galvanized inner fenders, although some of them look "blackish"The part that bolts to the firewall is plain steel. The only ones that are any different are the Broncos, which have an extra bracket on the inside of the fenserwell and that little gizmo ( I believe that's the correct technical term ) that is mounted in the center of the firewall and fits into a doohicky ( more hi-tech phrasiology, try to keep up ) thats mounted on the hood
78 F150 4x4
73 F100 2wd
79 Bronco
79 Bronco
Old Mar 7, 2009 | 02:57 PM
Jermafenser
The '79 Bronco extras is what the OP was asking about.
It's to reinforce the hood in an even of a crash and to protect the weak fiberglass toppers back there. Older hoods become projectiles when it gets involved in a front-end collisions. 78/79 were the only years which the hoods would crumple. Also, if equipped with the reinforced brackets, the upper bracket on the hood hinges will pierce the cowl so the hood will stay in its original place.
Old Mar 7, 2009 | 09:35 PM
shack's Avatar
shack
Thanks to all,
I'm glad to see what I got is original!
Joel
HillBillyBuddha
Electrical Systems/Wiring
Apr 30, 2013 06:14 PM
rjinator3.0
Nov 29, 2012 10:54 AM
shack
WTB - Ford Trucks & other vehicles
Jan 12, 2012 10:01 PM
shack
1966 - 1977 Early Broncos
Mar 19, 2005 11:24 PM
shack
Oct 18, 2002 01:27 PM
