Repairing some rust
>cab+box rocker panels). I hope to reapir all the rust over
>this summer. I have no experience and dont know where to
>start. I plan on buying a new tailgate and drivers door
>because of dents. What whould anyone reccomend doing. I know
>there are several different ways to go about this job. Any
>suggestions for any stage of the job would be great thanks.
The best way to deal with rust is eliminate it, this may include cutting out the rust and splicing in patch panels or rocker panels, depending on the amount of rust and how coarse it is.
If its light surface rust, you could try sand or media blasting.
Then sealing the bare metal. I prefer to use an epoxy primer-sealer.
In any case, it sounds like you have a complete on you hands and is by no means a small job.
But as most things, practice makes perfect, or at least better.
Working with body fillers is somewhat like drywall joint compound, as far as sanding and smoothing. There are various types of fillers out there also , depending on the type of fix.
Replacing doors, fenders and tailgates are a simple bolt ons, if you have a buddy to help, it will be that much eaiser.
In my opinion its easier to hang a door than to transfer the guts, but its nothing you cant do with basic hand tools.
Hopefully this is not your daily driver and you wont have to "hurry" to get it done, the more time you take to make sure things line up and are smooth, the better it will look when your done
Well, hope I helped a little anyhow, good luck and keep me posted.
Thanks,
Ron
