Bed rust
Old Apr 17, 2002 | 01:32 AM
okie65's Avatar
okie65
Bed rust
I have a 65 F100 that has rust holes about 8-10 inches long and maybe ¼ inch in width at the fwd edge of the bed, just behind the cab. I was wondering what would be the best way to repair this and would a spray in bed liner be wise? Other than that the bed is in pretty good shape. I just want to use it not show it. Would the metal bonding work or should I have it welded? I also seen some bed liner sheets in JC Whitney…are they junk or would that be a suitable repair. Lots of ????:-
:-X11
Old Apr 18, 2002 | 05:00 AM
CustomCab4x4's Avatar
CustomCab4x4
Bed rust
Are the holes in the verticle part or the floor itself ?
Phil
>behind the cab
Old Apr 18, 2002 | 09:33 AM
okie65's Avatar
okie65
Bed rust
Yes, it's on bed itself, but it runs left to right at the front wall of the bed. Does that make sense?
DB
Old Apr 18, 2002 | 06:50 PM
CustomCab4x4
Bed rust
<<<Yes, it's on bed itself.........>>>
Just to make sure I understand.....is the rust IN the floor OR is it in the vertical panel at the front of the bed, and NOT in the floor?
Old Apr 18, 2002 | 10:43 PM
okie65's Avatar
okie65
Bed rust
It's at the floor where it meets the vertical front side of the bed. I guess you could call it the angle. If I just wanted to "farmerize" it I could just take angle tin and rivet it on, but I would like a more professional look. Does that help any?
Brian
Old Apr 18, 2002 | 11:46 PM
CustomCab4x4
Bed rust
[updated:LAST EDITED ON 19-Apr-02 AT 00:49&nbsp;AM (EST)]Brian, you really need to get that rust out of there or it will only get worse. Dirt and crud collect between the floor and the top of the support channel and then it stays wet. I don't know if those 'repair panels' match closely enough to use to patch it or not. The front panel is popcorn to repair compared to the floor. I made a repair panel for mine that worked out pretty good. If you want take a look in the gallery. I included a link. Look in Garage Queen. Good luck,
https://www.ford-trucks.com/user_gallery/displayalbum.php?&userid=234&albumid=206
https://www.ford-trucks.com/user_gallery/displayalbum.php?&userid=234&albumid=454
Old Apr 19, 2002 | 11:01 AM
okie65's Avatar
okie65
Bed rust
Phil! Thanks.....looked at your pics.....you are GOOD! Anyway, thanks for your help, though I don't think I'll be able to accomplish what did, just wanted to patch. But you're right need to fix it now before it gets bigger than me. Thanks again
Brian
Old Apr 19, 2002 | 05:42 PM
DAV1972's Avatar
DAV1972
Bed rust
640 CI Aluminum FORD
2009 - 2014 F150
42
Jan 22, 2017 09:01 PM
scooterspal
1983 - 2012 Ranger & B-Series
Jun 14, 2016 10:08 AM
BlueBeauty
Jun 12, 2016 07:29 AM
drew.hinds10
Jun 14, 2015 03:20 PM
dh_meyer
2009 - 2014 F150
Apr 10, 2015 03:47 PM
