brake squeal
Old Mar 6, 2009 | 04:33 PM
61 uni's Avatar
61 uni
brake squeal
Ok, pads have been on for two weeks and this one squeals(almost sounds like metal to metal under HARD braking. Rotor is smooth front and back, pads and clips look fine. Any ideas?
Old Mar 6, 2009 | 06:57 PM
crum71's Avatar
crum71
1/8 mile Oval Track
What kind of pads did you put on it? Did you have the rotors turned? I really don't have any ideas, pretty sure someone will chime in to give you the correct answer though.
Old Mar 6, 2009 | 08:12 PM
61 uni's Avatar
61 uni
wearever gold from advanve. thry didn't need turning.
Old Mar 6, 2009 | 10:52 PM
Ponyboychris's Avatar
Ponyboychris
Slide pins are in good shape, right? All the clips and anti-rattle wires are installed? Did you tear it apart to see if something is wedged in there?
Old Mar 7, 2009 | 06:25 AM
mxracer3276's Avatar
mxracer3276
Subscribing, have the same problem but irt's only on my front driver side rotor.
Old Mar 7, 2009 | 06:31 AM
61 uni's Avatar
61 uni
I'm going to take apart today and lube the pins. Matt ever had a problem with the pinion seal leaking?
Old Mar 7, 2009 | 07:01 AM
mxracer3276
No i haven't. I am actually going to lube up the slide pins as well today. Pissed me off though man, brand new pads and that side is squealing like they're 10 years old!!
Old Mar 7, 2009 | 07:39 AM
fuelit's Avatar
fuelit
I have found out to go with softer cheaper pads and change more often, also saves rotors.
Old Mar 7, 2009 | 08:18 AM
jdecker88's Avatar
jdecker88
I went with Hawk Pads and I haven't had any squeaking.
