quick answer needed
Old Mar 5, 2009 | 06:38 PM
buzzr48's Avatar
buzzr48
quick answer needed
where do I find the exhaust flange gasket size for a '79 ford f-150 351m? Can't seem to find any info on this at all. Thanks
Old Mar 5, 2009 | 10:04 PM
73f100shortbed's Avatar
73f100shortbed
I did not find any info on a flange gasket for 79. Are you talking about where the y-pipe bolts to manifold? I did find an exhaust flange gasket listed for 78 on rockauto.com and it lists it as 2 1/32" ID. I'm not sure how accurate this info is. Do you have the old one out? Maybe a local exhaust shop could match something up for you. Maybe NumberDummy will come along with some info on Ford part numbers for you.
