F 250 6 inch lift pictures
Old 03-06-2009, 09:50 PM
TheTinian's Avatar
TheTinian
TheTinian is offline
Here is my 77 with the 8" Super Duty Springs in the front and 38" TSL's.
I liked the way it sat and the tires fit well, But it still needed to go higher. So here it is at about 14" of lift with 40's. (Tires are WAYYYY to small.)
Old 03-07-2009, 09:12 AM
Ronzi's Avatar
Ronzi
Ronzi is offline
Originally Posted by Dr. Dirt
Ronzi, did you notice the Bud Light can in the first pic?
HAHA! No I never noticed that. Good eye !
Old 03-08-2009, 10:55 PM
nkapphahn's Avatar
nkapphahn
nkapphahn is offline
I have ordered a 6" Skyjacker w/ springs front and rear for my 1978 3/4 ton Supercab. The cost for the springs and hardware was just over $1,000 on jegs.com. It cost a few hundred more for pitman, drag link, and brake lines. I will be installing next week and have a few questions. Has anybody had pinion angle issues? Are angled axle pad shims recomended? I also believe the front driveline may need to be lengthened. Any input would help. Thanks
Old 03-11-2009, 08:10 PM
Cobra Highboy's Avatar
Cobra Highboy
Cobra Highboy is offline
Hey 75350,
By using the front shackle on the rear are you able to keep the factory towing rating? the reason I ask is that looks like a great idea but I tow and haul 10,000 plus a lot. I would like to do that to my truck but need to keep the tow/haul rating up. I had no idea about the superduty springs either I am definately going to look into that.
Old 03-11-2009, 09:21 PM
JBradley500's Avatar
JBradley500
JBradley500 is offline
close to 6" (not a perverted joke) with 39.5" tires. old picture.
Old 03-12-2009, 12:59 AM
Hurk76's Avatar
Hurk76
Hurk76 is offline
Ok I found A guy locally who can get me a new set of 6 inch skyjacker front springs for $325 and he thinks if I do the sky manufacturing shackle flip it will sit level. What do you guys think? I know I'll still have deal with steering but I want to get the ride height right first. Thanks again.
Old 09-07-2015, 11:42 PM
fordhighboy343's Avatar
fordhighboy343
fordhighboy343 is offline
can someone tell me what size lift this is just bought truck the guy i bought it off couldnt tell me
Old 09-07-2015, 11:43 PM
fordhighboy343
the guy I bought it off of couldn't tell me what size lift it was
Old 09-08-2015, 07:36 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,326 Likes on 2,475 Posts
Welcome to FTE, boy you dug a old thread, that's ok. Looks like your truck is a F150 1/2 ton with coil springs and radius arms for the front suspension. The trucks in the above thread are F250 with leaf spring front suspension, just so you know.
We need to at least know your tire size, I guess 33's or 35's? And I spy a little day light and a body lift block in the passenger side front cab mount. So that is probably a 3" body lift? And looks like you have a snow plow q/d set up on the front. If you are not going to be plowing, ditch that extra weight ASAP.
If you have 31's then looks like no lift, but a 3" body, if you have 33's still the 3" body lift and maybe a 2.5 suspension lift?
35's... still the body lift and maybe a 3" suspension lift? Go look at the rear axle, do you have 1 block between the leaf spring and the axle or 2 stacked together.
FYI if you have one with a "wing" sticking out (for you bump stop to hit) that is a factory block that all old Ford trucks have.
VMPowerstroke
11-24-2021 07:50 PM
jgdrcr
08-29-2016 01:30 PM
1bad78
10-02-2015 02:49 AM
F-250 6.2L
1999 to 2016 Super Duty
08-31-2015 09:32 AM
Quick Reply: F 250 6 inch lift pictures
