Torque Specs??
Old Mar 5, 2009 | 12:19 PM
00Dave's Avatar
00Dave
Torque Specs??
I know I know, I've seen the specs time and time again. After trying to use the search, I still haven't found them. Looking for the torque specs for under valve cover items. I am thinking about changing out the glowplugs and thought I would go ahead and do the maint. while in there. Thank you folks.
Old Mar 5, 2009 | 12:21 PM
F350-6's Avatar
F350-6
Rocker arm pedestals circled in red to 20 ft-lbs
Lower injector hold down bolt circled in blue to 120 in-lbs
Glow plugs to 14 ft lbs
Old Mar 5, 2009 | 12:46 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I did find that pic Chris, , but couldn't remember the #s.
Old Mar 5, 2009 | 02:02 PM
F350-6's Avatar
F350-6
Find the one Robin has. He's got the numbers included in his pic. I did good just getting the circles on mine.
Old Mar 5, 2009 | 02:04 PM
00Dave's Avatar
00Dave
Thanks guys. I just bought a 1/2" drive torque ratchet. I didn't look to see if it was ft. lb. or in. lb. My bet is ft. lbs. Guess I'll need to try and calculate for the in. lb. Sure do appreciate your responses.
Old Mar 5, 2009 | 02:08 PM
miller_feed
I would get the 1/4" drive torque ratchet. The 1/2" drive will not give you a true reading that low.
