Sponsored by: Real Truck
How do 05+ Headlights attach?
Old Mar 4, 2009 | 11:06 PM
Armadaskis's Avatar
Armadaskis
Exclamation How do 05+ Headlights attach?
What type of hardwear do the 05+ headlgihts use to bolt up to the header panel???
I just upgraded from a 03 front and dont have any hardwear... It it just a "U" nut & bolt???
Does the beam not adjust?
**Also does anyone know the part number for a 03 bumper filler? I can't seem to find it...
Old Mar 4, 2009 | 11:56 PM
DCSpecial's Avatar
DCSpecial
On the bottom you use the same screws that hold the 99-04 corners in.
On top you can get a speed nut at a screw or just screw it to the header panel.
They don't have side to side beam adjustment, but they do have a vertical beam adjustment. It looks like a torx bit sticking up on the top of the housing, you can use a 5/32" six point socket to adjust it.
