New box side skins
Old May 26, 2002 | 11:57 PM
trinogt's Avatar
trinogt
New box side skins
I heard today that some shops cut old box sides off and flange the existing metal, and glue the custom-cut panels to that flange with body adhesive. That way, you don't have to grind any tack welds, or pull the box off! Is this something I should look into, or should I borrow a welder, grind all the old tacks away and peel the skin off, and tack weld a new skin on like factory???
Mark
Ford started it; Ford will finish it!
Old May 27, 2002 | 09:59 PM
FortyFords's Avatar
FortyFords
New box side skins
is this a truck that you are restoring or a truck that you are just fixing rust on and not a keeper?
if restoring do it right
Some shops do this to save time and charge you for the other way(rip you off)
if it was me I'd do it the right way drill out the spot welds and put the skins on like the factory
just my 02
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old May 27, 2002 | 10:14 PM
trinogt's Avatar
trinogt
New box side skins
That is what I was thinking... I mean, the box is off anyway, so I have access to the front wraparound... I might be able to borrow a mig welder, but it is the flux-wire type... Will this work okay for the welds? I mean, I think even the factory used just spot welds to build the box... Right?
I just hope the aftermarket panels look nice to start with...
Mark
Old May 28, 2002 | 10:10 PM
FortyFords's Avatar
FortyFords
New box side skins
That mig should work okay !
Here something else to think about !
I would try and cross brace the bed somehow before taking old skins
of it could get out of alignment or twist making it a bear to put the new metal on? especialy because you have it of the frame.
Just my $.02
Rich
not with rocks
Old May 28, 2002 | 11:54 PM
trinogt's Avatar
trinogt
New box side skins
Thanks for the tip! I suppose I could cut plywood gussets the complete width of the box in two or three spots...
When we welded the box end (tailgate posts) last week, we couldn't get the driver's side up as high as the passenger, and still get the tailgate to close... Pretty touchy job! We used a come-along, jack, measuring tapes, etc etc... But still couldn't get it satisfactory. Oh well, at least the sides don't flap in the breeze anymore! And I don't have to squeeze the box sides together to get the gate to latch anymore!
Has anyone done a complete box side full skin replacement here? I am wondering how the wraparound areas work; if ou have to beat them flat around the front of the box???
Mark
Old May 29, 2002 | 11:43 PM
75crew's Avatar
75crew
New box side skins
Try a search. There was a thread going about this topic about a month ago. One fella did what you're talking about and said it went pretty well.
Old May 30, 2002 | 06:57 AM
Blaine's Avatar
Blaine
New box side skins
AXracer
May 8, 2015 03:42 PM
clintonvillian
27
Apr 27, 2015 09:52 PM
52 Ford F1
Dec 7, 2014 11:33 AM
topmoo
May 20, 2014 09:24 AM
fordxxx
Paint & Bodywork
Sep 2, 2004 02:56 PM
