I hate these stripes!
Old Mar 4, 2009 | 05:07 PM
jpcnorthwood's Avatar
jpcnorthwood
My 94 F150 has some ugly cracked stripes that run the entire length of the truck. Do any of you guys have or know of a way to remove pinstriping without damaging the paint? Sorry I would post a picture of the stripes but I am new to the forum and don't think I can do that yet.
Thanks, jpc
Old Mar 4, 2009 | 06:18 PM
Action4478's Avatar
Action4478
If they havent been painted around ,,you can use a 3 M stripe eraser
Old Mar 4, 2009 | 11:01 PM
Chaosracing's Avatar
Chaosracing
If its the tape stripe and not painted over or around, use a hair dryer or heat gun to soften the adhesive up. Start at a corner of the stripe, heat very carefully (you only want to soften the adhesive up) then start peeling it off. You can then use a wax and grease remover afterwards to remove any residue left over.
I have used the 3m eraser already, but if you dont know how to use it properly, you can burn thru the paint. It does a nice job, just be carefull if you choose this method. It also removes the adhesive as well.
Warning: #1 If you have never done this before, I highly recommend using the hair dryer first.
#2 If it is a 2 tone paint, you will wind up with a ridge in the paint that the stripe was hiding. There also might be primer showing thru if truck was repainted and they failed to overlap the paints.
Old Mar 5, 2009 | 02:03 PM
jpcnorthwood
Thanks, I will try the heat gun first. They are not painted over and the truck is solid red. I doubt it has ever been repainted, the last owner just used it for work and didn't love it the way it should be loved. It really is a shame, but it gives me something to this summer.
Old Mar 21, 2009 | 03:46 PM
hoobatech's Avatar
hoobatech
also depending on how sunfaded your truck is, after the stripes are gone you might have red stripes still that are the original shade of the truck, which is probably still a hundred times better looking than cracked stripes
Old Mar 22, 2009 | 12:40 AM
DasCheckers's Avatar
DasCheckers
I recommend the eraser wheel man.
They should run about $10.00 anywhere.
Just go slow and you'll be fine, don't stay in one place for very long or you will burn through the paint.
Feel the spot right after you work it and if it's hot to the touch move faster!
The fading will be there either way.
Then an adhesive remover, a deep wash, more adhesive remover, a fine grit polish, then another finer grit polish, another deep clean, then buff, then as always a good coat of wax!
Old Mar 25, 2009 | 09:03 PM
jpcnorthwood
Is it something I can find at Auto Zone or any parts store?
Old Mar 25, 2009 | 09:37 PM
DasCheckers
I get them from the body shop supply but I've also found them at O'Reillys, just ask Auto-Zone, they might have one.
kraylake
Jan 3, 2012 08:19 PM
Brown Falcon
21
Jul 18, 2009 05:23 PM
bwguardian
Apr 30, 2008 12:50 PM
njstevens
Feb 25, 2008 10:21 AM
Ron
Dec 6, 1999 11:39 PM
