Spark Plugs
Old Mar 4, 2009 | 02:43 PM
nnero's Avatar
nnero
Spark Plugs
Last time I did a tune up, I changed the plug wires, distributer cap and rotor. I had someone else put new plugs in a couple months later. I checked some of the plugs the last time I changed the oil and they were autolite platinums. So these are not copper like everyone here says to use? I did not pick out the plugs. My truck did seem to drop a few mpg after this and had less power. Should these be changed ASAP.
Old Mar 4, 2009 | 02:53 PM
quicklook2's Avatar
quicklook2
motorcraft copper or ngk copper.
do it.
Old Mar 4, 2009 | 04:12 PM
nnero's Avatar
nnero
I will definitely be doing this as soon as I can. How come the people at the parts stores dont say anything? I had never heard about that before this site. Thanks
Old Mar 4, 2009 | 04:19 PM
quicklook2's Avatar
quicklook2
because most do not care.
most are there to sell things that cost he most.
Old Mar 4, 2009 | 04:26 PM
nnero's Avatar
nnero
Yeah, I figured that but I thought that after seven years and two vehicles someone would have said something to me. Thanks for the info
Old Mar 4, 2009 | 04:38 PM
quicklook2's Avatar
quicklook2
some of these trucks have no problem with regular platinums but that has not been the case for me.
Old Mar 4, 2009 | 04:44 PM
nnero's Avatar
nnero
Right after the plugs were changed I noticed a loss of power and my fuel milage dropped from 16-19 to 14-16. I re-checked the gap and that was fine so i figured it was something else (it is an old truck after all). Maybe this is the solution I am looking for. It def cant hurt anything
Old Mar 4, 2009 | 05:29 PM
EPNCSU2006's Avatar
EPNCSU2006
Check MOTORCRAFT PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES for the OEM plug number. I know a lot of the newer trucks came standard with platinum plugs.
I say this every time this topic comes up, but no one seems to listen: the only difference between a motorcraft platinum and a plain motorcraft copper plug is the plating material on the electrodes. Internally, they have the same copper core. The platinum on the electrode tips makes for a longer service life and doesn't change the performance of the plug any appreciable amount, and if that's what OEM calls for, it doesn't hurt anything to run.
It shouldn't hurt anything where the standard copper plug is called for either, but unless you hate changing plugs every 25-30000 miles, there's really no reason to run the motorcraft platinums. They shouldn't cause any problems, though, if you want the longer service interval.
What kind of cap, rotor, and wires did you install?
Old Mar 4, 2009 | 05:33 PM
nnero's Avatar
nnero
I dont remember what wires, cap and rotor i got, but they were the premium ones. $50 or so for the wires. I didnt get the plugs changed until a few months later. The truck ran a lot better after the wires and i did not notice a difference until after the plugs were changed. I was expecting a big difference cause the old plugs were worn out.
Old Mar 4, 2009 | 05:58 PM
EPNCSU2006's Avatar
EPNCSU2006
What was the plug gap? It should be .054-.056" for a 95.
The motorcraft site lists both a platinum and standard copper plug for a 95 F150 302, so that probably means the standard copper plug was original equipment. The platinum shouldn't make a difference, but the copper plugs are not so expensive that you couldn't try a set and see if they made any difference.
Old Mar 4, 2009 | 06:45 PM
nnero's Avatar
nnero
The gap was set to the sticker under the hood. I took the plugs back out to double check and they were fine. I will pick up a set of copper plugs next time I change the oil and see if there is a difference.
