Rear end gears
Old Mar 3, 2009 | 09:23 PM
nnero's Avatar
nnero
Rear end gears
I have heard many, many people complain about the 3.55 gears in trucks with the 4.9 and 5.0. What is involved with switching them and what should I switch them with 3.73s? Is this a costly project? I did a search and didnt seem to find much. Hope this question doesnt sound dumb. I dont know things like this but am trying to learn.
Old Mar 3, 2009 | 10:36 PM
Conanski's Avatar
Conanski
3.55 gears are fine in a 4.9 or 5.8 truck with tires up to about 30", and it's also a good overall ratio for the 460 trucks as long as it has overdrive. The 5.0 is the weakest motor in the stable in terms of TQ so it needs more gear, these trucks should have come from the factory with at least 3.73's IMO. If you have plans for bigger tires and have an OD tranny then jump right to 4.10. It's not cheap to have a shop change gears, I have seen quotes as high at $1500 for a 4x4. The parts themselves cost about $250 per axle and it is possible to do with basic hand tools if you're mechanically inclined, most places that sell gears will also sell a video of the install procedure.
Old Mar 3, 2009 | 11:35 PM
TexasGuy001's Avatar
TexasGuy001
I agree with Conanski.
Also, I wish my truck had 3.73.
Old Mar 4, 2009 | 09:56 AM
str8dogg's Avatar
str8dogg
I have 3.55 gears on my '89 302 / M5R2 and I am running 31's on 15" rims. I don't do much hauling, racing or other stress things with my truck and they are doing fine. If you decide to go above 31's, like mentioned earlier you will need to change out the gears, yo might as well go straight to the top with 4.10s.
Old Mar 4, 2009 | 10:06 AM
lew52's Avatar
lew52
Your gear selection should be made on what you use the truck for ..what you want out of it ...& most important tire size...
Old Mar 4, 2009 | 10:20 AM
stangbanger's Avatar
stangbanger
35 bfg mudd terrains, 355 gears 302. And shes quite a turd! But i dont wheel her or go racing at this point and i def wont go wheeling until i upgrade! i can get into 5th gear on the highway but i am riding at 1500 to 2000 rpms. And the 302 just doesnt get into her power band so going up hills is a drop to 3rd gear!
What are the front gears i need for my TTB front end? Arent they special for the houseing?
Old Mar 4, 2009 | 10:54 AM
nnero's Avatar
nnero
Right now I have 31s and the truck is good enough for me. Eventually I will get another vehicle so I dont have drive my truck everyday. At this point I will go through the truck the way it should be done. Its very hard to do that with a daily driver. I plan on eventually having 33s. At that point in time, a gear swap will done. But this is in the future and keeping the truck going and not looking completely like crap is my main priority. Thanks everyone, I love this site so much. Why did 3.55s come with 5.0s in the first place? For gas mileage?
Old Mar 4, 2009 | 11:22 AM
lew52's Avatar
lew52
Mine came with 308s but it is 2wd....If you go to 33s 410 would be good you could even go 456 if you want.. Lew
Old Mar 4, 2009 | 12:14 PM
1966Tbird's Avatar
1966Tbird
i just bought a set of 4.56 gears like an hour ago and i'm putting them in i got tired of my 3.73s and 33in tires i would recomend at least 4.10 gears with 33s............if you want to buy my 3.73s just pm me
Old Mar 4, 2009 | 03:38 PM
Rulebreaker's Avatar
Rulebreaker
It's a HP Dana 44. Reverse cut gears are needed. RB
Old Mar 4, 2009 | 04:17 PM
nnero's Avatar
nnero
Tbird: as much as i would like to I do not have the extra money right now. I always get excited thinking about what my truck could be with just a little extra cash. Right now I will just concentrate keeping the truck reliable. Thanks for the offer.
Old Mar 4, 2009 | 05:12 PM
1966Tbird's Avatar
1966Tbird
no problem if you ever change your mind they will probably be resting in my garrage for years to come just send me a pm
Old Mar 5, 2009 | 12:10 AM
stangbanger
What is this thick cut gear i keep seeing? Will a 488 go into my 44 front housing?
Old Mar 5, 2009 | 05:28 AM
Rulebreaker
Depending on what carrier you have you can go as low as 5.13. I cant remember off hand where the carrier break is on a 44, but I had to change carriers when I went from 3.55 to 4.56. RB
Old Mar 5, 2009 | 06:06 AM
DH8838's Avatar
DH8838
I have 37's on my truck with stock gears, so i found a guide that says put 4.88 or 5.13 gears on it, i think i'll go with the 4.88 for my truck
