Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
4X4 LIGHTING????
Old Oct 18, 2002 | 12:40 AM
97 awd xlt blue's Avatar
97 awd xlt blue
4X4 LIGHTING????
01 sport trac 4x4 black
97 explorer xlt AWD v8 blue
91 f-250 xlt lariat 4x4 blue/gray
84 ranger xlt 4x4 black
94 explorer xlt 4x4 purple/gray
96 explorer limited 4x4 green
how hard would it be to add 4x4 to a 2003 lighting i would really like a lighting but i also need 4x4 any ideas how hard it would be??
Old Oct 20, 2002 | 03:16 PM
97 awd xlt blue
4X4 LIGHTING????
ANY ONE????????
Old Oct 22, 2002 | 02:44 PM
Doorgunner808's Avatar
Doorgunner808
4X4 LIGHTING????
It would be easier and probably cheaper to build or buy a Lightning 5.4s/c and transplant it to a truck that is already 4wd than trying to convert a Lightning to 4wd.
DG808
Old Oct 23, 2002 | 09:57 PM
ford man dick's Avatar
ford man dick
4X4 LIGHTING????
Old Oct 8, 2003 | 08:19 AM
lightning_strike's Avatar
lightning_strike
actually the transition would not be all that difficult.. on the other hand it would be extremely costly.... to perform the change all you would need is to aquire a 4wd front axle 4x4 tranny and transfer case and and go to advanceadapters.com and have them build you an adapter to fit the tranny to the block ( approx 1500.00 just for adapter) send the vehicle computer system to a plant in houston, TX ( advance adapters can give you numbre dont have it off hand) and bolt all togather CUT hole in floor to install 4wd shifter.. that is the basic steps of course it will not be that easy it will take a good amount of time as wel as money..probably in the high 4-5K range but if that is what you want it can be done.
Old Oct 12, 2003 | 01:23 PM
YZBot's Avatar
YZBot
hello, I'm new to this forum and just registered, but this idea is exactly why I registered. I'm a die hard lightning fan but can't drive one because it only come in rwd. I want 4wd so I can make it an all season vehicle. I live in the snow belt. My approach is going to be a little different. I'm going to take a reg cab, short box, 4x4 and make it 90% lightning. Lower it, suspension work, wheels, tires, and of course a supercharger. I plan on useing the 04 so at the moment I'm still in the planning stages. besides, I'm still paying for current car.
Old Oct 13, 2003 | 02:49 AM
red03SVT's Avatar
red03SVT
what's a "lighting"?
-Mike
Old Oct 14, 2003 | 03:45 PM
cowtown's Avatar
cowtown
Shouldn't be too hard to do what you want with a 97up truck. Probably what I'll end up doing too.
Old Oct 21, 2003 | 09:55 PM
DRdetails's Avatar
DRdetails
Sounds good, keep in mind as of right now, I don't think there is a blower set up for the '04 24v 5.4 triton engine, and I doubt 16v part will work. You'd be better off getting a new or slightly used 2003 4x4 5.4, but if you get the lightning engine, fine, I doubt the stock tranny and transfer case will stand up to the power.
Old Oct 29, 2003 | 06:13 PM
J Selman's Avatar
J Selman
You would also need a 4x4 frame.4x4s use torsion bars where 2 WD use coil springs.The front diff. also mounts to the frame which the 2wd has no pervisions for.
Johnny
Old Nov 4, 2003 | 05:23 AM
Ratsmoker's Avatar
Ratsmoker
I saw a 4X4 lightning at the track. I don't know if the guy paid the dealer to do this or if he did it himself but it looked just like a lightning except it was higher and had a front differential. He could only muster a 15.4 due to the extra weight.
Old Nov 5, 2003 | 12:38 AM
BVFD1983's Avatar
BVFD1983
AWD would be really sweet in a Lightning... 4x4 wouldn't really do much for me in a SPORT truck made for speed and handling.
Old Nov 9, 2003 | 08:04 AM
tmk411's Avatar
tmk411
Lightening 4x4
Depending on how much 4xing you do you may want to look at also getting a straight axle in the front. If you do any off roading at all you'll like a lot better than the independant front end. If you just using mainly highway or roads stick with the independant though. Better handling! Just thought I would through that out. If your going to spend the money anyways.
Heres a good qeustion: Why hasn't the SVT group come out with anything like that yet? Something that is very capable in off roading.
TMK
Old Nov 9, 2003 | 08:44 AM
Shift1's Avatar
Shift1
Its too bad you don't want to do it to a Gen 1 Lightning. I believe the bolt holes are all there to do the swap. All you would need is a doner truck with all the 4x4 stuff. As far as the new trucks, I think it would be cheaper to get a regular 4x4 truck and put on a blower/lower it. Bell Tech makes a lowering kit for the 4wd Fords.
As far as actually NEEDING 4wd, my winter truck is my HD. The positrac rear end is plenty of traction for me. I have already driven it in some of the iciest conditions I have ever seen in 12 years of driving in Alaska. I am going to continue using my stock 20" tires, too. No problem.
Old Nov 9, 2003 | 07:15 PM
ecarter50's Avatar
ecarter50
4wd is bolt in on a 1st Gen Lightning, they even have the 4x4 indicator light from the factory.
