3.03 tranny
Old Mar 4, 2009 | 06:10 PM
80F-100 2wd's Avatar
80F-100 2wd
Originally Posted by 82F100SWB
Yep, pretty much any 'ol truck 4 speed will bolt right up to your bellhousing, just need to cut the floor out for the shifter and access panel, and maybe change out the slip yoke on the driveshaft.
With the tall rear end gears(2.75's in the couple I had,) a 300/NP435 combo actually works pretty good.
I have been kinda wanting a 4 speed in my truck. I would hate to have to cut another hole in the floor though. I don't know how to weld so i couldn't patch up the first hole thats been cut when my dad and I converted the truck to floor shift. Which I think is why the trans ended going out. Both the floor shifters (Mr Gasket universal 3 speed, Hurst Indy) had problems with getting stuck between gears when I shifted between 1st and 2nd. I have since fixed the problem.
My friend is actually supposed to check out this 80-86 F-150 thats abandoned at the apartment complex he works at and see what trans it has. It's supposed to have rust free body panels too. I could use them panels. Got quite a few rusted out ones.
Old Mar 4, 2009 | 06:12 PM
80F-100 2wd
You have lots of tranny options if you want to change to something else too.
Do you know if a T-5 out of a 93 mustang will work in my truck? I plan on putting a better trans in my mustang when I build my stroker motor.
Old Mar 4, 2009 | 06:24 PM
Franklin2's Avatar
Franklin2
Not sure about that, since it never was offered behind a truck. And I believe you would have shifter problems too, since the shifter is so short, and may be in the wrong place.
Stick with the truck trannies, and they will work. Here's the trannies they list for a 1980 f100.
A.T., C4
A.T., C6
M.T., 3 spd
M.T., 4 spd, Ford OD
M.T., 4 spd, Warner, 12" ext
M.T., 4 spd, Warner, 4" ext
Here's the ones they list for a 1980 f150
A.T., 4x2, 8-351M (5.8L)
A.T., 4x2, 8-302 (5.0L)
A.T., 4x2, 6-300 (4.9L)
M.T., 4 spd, New Process, 4x2
A.T., 4x4, 8-351M (5.8L)
M.T., 3 spd
A.T., 4x4, 8-302 (5.0L)
M.T., 4 spd, Warner, 4x4
M.T., 4 spd, New Process, 4x4
M.T., 4 spd, Warner, 4x2, 12" ext
M.T., 4 spd, Warner, 4x2, 4" ext
Here's the ones they list for a 1988 f150. If you wanted a 5 speed tranny, I would shoot for the Mazda/Toyo unit.
A.T., 4x2, C6
A.T., 4x2, AOD, 6-300 (4.9L)
A.T., 4x4, AOD
A.T., 4x4, C6, 8-351 (5.8L)
A.T., 4x4, C6, 6-300 (4.9L)
A.T., 4x4, C6, 8-302 (5.0L)
A.T., 4x2, AOD, 8-302 (5.0L), 10-1/4" ext hsg
A.T., 4x2, AOD, 8-302 (5.0L), 11-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext
M.T., 4 spd (Warner T-18), 4x2, 4" ext
M.T., 5 spd, ZF, 4x2
M.T., 5 spd, ZF, 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, 2.73 ratio
M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, 3.08 ratio
M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, 3.55 ratio
M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, 4.10 ratio
M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
Here's some places in Ohio that have a used 5 speed tranny.
1990
Transmission
Ford Truck F250 SHIFT LEVER LOOSE 05A023 $550 Earl's Cars & Parts USA-OH(Sciotoville) E-mail 1-800-382-3457
1992
Transmission
Ford Truck 150 XLT,4.9L,5 Sp,RWD,Tilt,Floor,ID D2285 $500 Dad's Auto Parts, LLC. USA-OH(Holland) E-mail 1-419-865-6599 / 1-866-990-3237
1988
Transmission
Ford Truck 150 5SP,4.9,MAZDA,3.08 8671 $450 Lancaster Auto Recycling USA-OH(Lancaster) E-mail 1-800-860-1297
1988
Transmission
Ford Truck F150 check ratio 145,000 CAR1 $450 Northeast Auto Recyclers USA-OH(Conneaut) E-mail 1-440-599-7078
1988
Transmission
Ford Truck F150 M.T., Mazda/Toyo Kogyo, 4X2, 2.73 ratio- 400 $450 306 Auto Parts & Wrecking USA-OH(Novelty) E-mail 440-338-4000
1989
Transmission
Ford Truck F150 M.T., Mazda/Toyo Kogyo, 4X2, 3.08 ratio- $400 American Auto Towing & Salvage, Inc. USA-OH(Geneva) Request_Quote 1-800-436-4256 Request_Insurance_Quote
1991
Transmission
Ford Truck F150 5SPD A2021 $360 Bumper to Bumper Auto Recyclers USA-OH(Akron) Request_Quote 1-800-348-6458/1-330-773-6871 Request_Insurance_Quote
1991
Transmission
Ford Truck 150 CHECK RATIO, DRIVES WELL 219,000 C BO1141 $350 Giant Automotive Products, Inc. USA-OH(Akron) Request_Quote 1-800-686-9000 Request_Insurance_Quote
1989
Transmission
Ford Truck 150 4.9I MFI,M5,CHECK RATIO 134,229 A JJ0667 $350 Budget Auto Parts Inc. USA-OH(Ashtabula) E-mail 1-440-992-1111
1991
Transmission
Ford Truck 150 5 SPEED-STILL IN 161,544 A 9726TF $350 Wayne Auto Parts USA-OH(Dover) E-mail 1-800-545-7809
1989
Transmission
Ford Truck F150 MT,TRANS CODE E9TA-CA-147K 147,000 A FOPU20 $300 Rt. 43 Auto Parts, Inc. USA-OH(Carrollton) Request_Quote 1-330-627-7700 Request_Insurance_Quote
1988
Transmission
Ford Truck 150 CKED OK 169,000 A JH3576 $300 Creston Auto Recycling USA-OH(Creston) Request_Quote 1-800-210-3349 Request_Insurance_Quote
1991
Transmission
Ford Truck F150 -MT 2WD TRANS CODE M 273 REAR RATIO-91K 91,000 A J71389 $300 A-1 Auto and Spring, Inc. USA-OH(Alliance) Request_Quote 1-330-823-7239 Request_Insurance_Quote
1989
Transmission
Ford Truck 150 m006 $300 Eagle Auto Parts USA-OH(Cleveland) E-mail 216-883-0500
1989
Transmission
Ford Truck 150 TESTED,5SPD,OD 111706 $299.95 Bob's Auto Wrecking USA-OH(Milan) Request_Quote 1-800-853-6266 Request_Insurance_Quote
1988
Transmission
Ford Truck 150 122,717 A JJ0709 $275 Budget Auto Parts Inc. USA-OH(Ashtabula) E-mail 1-440-992-1111
1990
Transmission
Ford Truck F150 MT, Mazda/Toyo Kogyo, 4X2, 3.08 ratio- A50444 $275 Joe's Auto Wrecking USA-OH(Northridgeville) Request_Quote 800-956-6380 / 440-377-0348 Request_Insurance_Quote
Old Mar 4, 2009 | 07:04 PM
85e150's Avatar
85e150
T5 from a V8 Mustang will work, but it requires an adaptor, and a tail shaft housing from a Chev S10 T5 so the shifter will be in the correct place. No heavy loads or towing....
Old Mar 4, 2009 | 07:41 PM
80F-100 2wd
thanks franklin2. Thats alot of trannys to choose from. I'll check some of that out. I just remembered earlier today that my best friends husband used to work at a transmission shop. I might try and get him to rebuild mine if he will do it for a reasonable price. I can always help him too to refresh my memory on how to rebuild a trans.
Old Mar 4, 2009 | 07:44 PM
80F-100 2wd
Guess i'll skip on the t-5 then. still want to be able to tow if I have to. Don't want to go to all that work adapting a trans to a daily driver. Hopefully one day I can get another truck and start restoring the ol F-100.
Old Mar 4, 2009 | 09:55 PM
82F100SWB's Avatar
82F100SWB
There should be need to weld anything up, the 4 speed trucks have a removable floor plate where yours is solid, where you probably had to cut it for the floor shift. One from an auto 4x4 truck would probably have the shifter hole pretty close to where you'd need it for the 3 speed.
You can see what I'm talking about here:
If you want a straightforward bolt in swap, stick with a 4 speed. A 5 speed will require a pedal swap, and drilling your firewall for the clutch master cylinder. Possibly a clutch swap too.
Old Mar 5, 2009 | 05:37 AM
80F-100 2wd
That removable plate is pretty cool. I deffinately wouldn't want to go 5 speed then. I hate hydraulic clutches. I just put a new 11" clutch in my truck last year. Def don't wanna be replacing it again. I hope maybe this abandoned truck my friend found might be a 4 speed and I can gank the tranny out of it.
yozsi
Jan 18, 2017 10:46 PM
Eagle299
Oct 9, 2014 11:06 PM
Missin'A Gear
Aug 30, 2014 10:23 PM
es2rider
May 4, 2011 01:40 PM
Blue Bomber
Jul 14, 2008 06:41 PM
