Sponsored by: Real Truck
What is the Minimum Rotor Thickness ?
Old Mar 3, 2009 | 07:31 PM
browntown3's Avatar
browntown3
Does anyone know the minimum brake rotor thickness on f350's ? My truck is getting some vibrations when braking and i want to turn the rotors but need to see if they are past the point of turning...Cant find the info anywhere.......Thanks guys ?
Old Mar 3, 2009 | 08:09 PM
stewcon's Avatar
stewcon
I think its stamp on the rotor, at least it use to be.
Old Mar 3, 2009 | 08:35 PM
1975StroppeBaja's Avatar
1975StroppeBaja
According to a workshop manual page I saved, for an '04, the minimum thickness is as follows:
Front - 1.417 in
Rear - 1.102 in
hope this helps
Old Mar 3, 2009 | 11:40 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Here is the info for '02 which is not all that different then what Jason already posted...
Minimum thickness to machine front brake disc = 36.6 mm (1.44 inch)
Front brake disc minimum thickness = 36.0 mm (1.41 inch)
Minimum thickness to machine rear brake disc (F-250 and F-350) = 28.6 mm (1.12 inch)
Rear brake disc minimum thickness (F-250 and F-350) = 28.0 mm (1.10 inch)
Old Mar 4, 2009 | 12:33 PM
browntown3's Avatar
browntown3
Thanks guys!!
fordman4597
Jun 20, 2018 10:07 AM
Nitramjr
Jul 15, 2017 07:59 AM
Itsthelaw
May 14, 2017 12:54 AM
reddog99
1983 - 2012 Ranger & B-Series
Aug 25, 2016 03:20 PM
atikovi
Nov 28, 2015 02:13 PM
