Torque specs
Old Mar 3, 2009 | 07:19 PM
grwagner's Avatar
grwagner
Question Torque specs
I have a 1980 ford F100 and I am needing the torque specs for the heads
Old Mar 6, 2009 | 10:35 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2011 F100 forum.
Welcome and thanks for joining us at FTE!
Old Mar 6, 2009 | 12:35 PM
Franklin2's Avatar
Franklin2
What engine do you have?
Old Mar 6, 2009 | 07:01 PM
grwagner's Avatar
grwagner
6 cylender 300
Old Mar 7, 2009 | 07:59 PM
Franklin2's Avatar
Franklin2
Step one 55 ft-lbs.
Step two 65 ft-lbs.
Step three 85 ft-lbs.
There is a certain pattern you have to follow also when tightening the bolts.
Old Mar 8, 2009 | 08:23 PM
bashby's Avatar
bashby
I have always just gone in a spiral pattern from inside out, sometimes they have you criss-crossing in the manual, but its always basicly a spiral from inside out wich should work fine unless youre building some 500hp monster
