Squeeky A/C ?
Old Mar 3, 2009 | 05:06 PM
460MAGNUM's Avatar
460MAGNUM
Squeeky A/C ?
Have had my new E-350 about a month and living here in Phoenix Az have had a chance to use the a/c a few times ,every so often I get a squeek or squeel sounds almost like a dogs squeek toy and it sounds like its comming from behind me ,it does have dual air and will make the noise even with the back air off ,any ideas ?
Old Mar 3, 2009 | 07:45 PM
HAB's Avatar
HAB
What your describing sounds like a squeeky fan. Start the van turn on the AC, get out and move to the front passenger side. If it still sounds like its behind you move to the rear of the van behind the drivers seat and listen. You should now know pretty much where it is. If its the rear remove the cover and unplug the fan. IF its the front its going to be a lot harder to get to. You may want a pro to handle the job. Your set up may not be as easy as mine was.
