Convert to dually?
Old Mar 3, 2009 | 04:50 PM
73-tileman's Avatar
73-tileman
Convert to dually?
This site is amazing with so much info. I'm new to the site with a new 73 F250 camper special, 2WD, 390. I am going to turn this truck into a way cool work truck and am considering putting a flat bed on it. What all is intailled in changing the rear end to dually. Any help would be great, and thanks in advance.
Old Mar 3, 2009 | 11:28 PM
79F150/F600's Avatar
79F150/F600
The prefered method would be to put a rearend in your truck out of a dually you can use an axle out of even an 80's ford. Obviously you will need 4 dually tires and rims and most likely a new ujoint for your driveshaft. Grabbing a dually rear with wheels out of a junkyard or a parts truck would be ideal.
Old Mar 4, 2009 | 12:52 AM
OrFordGuy's Avatar
OrFordGuy
dually swap
I used the 10 1/2 sterling with outboard drums under my 78'. I later converted it to discs off another 10 1/2. I also used the bolt on front adapters off a 92' Chevy dually to convert the front axle on my truck.
Old Mar 4, 2009 | 01:22 PM
Supercab's Avatar
Supercab
Wink
Arrowcraft - Dual Wheel Conversions
Old Mar 4, 2009 | 08:15 PM
73-tileman's Avatar
73-tileman
thanks for the link to the wed site, that will definately be the easiest route.
