Sponsored by: Real Truck
OnBoard Air
Old Mar 3, 2009 | 02:23 AM
richsoucie's Avatar
richsoucie
OnBoard Air
Has anyone put a belt driven compressor on a 5.4l f-250 i had an electric one and it was crap would much rather have a belt driven one. I know all the jeep guys are using york compressors and i know of one person that has put one on his 6.0l
Old Mar 3, 2009 | 05:50 AM
haywoodya69's Avatar
haywoodya69
I am about to install a compressor on my new f550 v 10. It is a v mac air compressor with 70 cfm output. i have one similar to that on my 92 f350, but it is a 35 cfm IMT piston. what kind of question do you have?
Old Mar 3, 2009 | 10:27 AM
richsoucie's Avatar
richsoucie
just wondering where to mount it and if anyone makes a braket it looks real tight in there and i havnt been able to find a place to put it where it will fit and still line up with the belt system
Old Mar 3, 2009 | 11:07 AM
haywoodya69
check out vmac.ca. yes one fits there and aligns with the belts. You install new bracket(all different for each engine) mount compressor etc. Not sure where it goes on your engine but the diesels go where the second alternator goes. WHole kit comes complete. However this is expensive. Unless you are going to use this for work where it will pay for itself this is really no good for personal use. And by expensive i mean 10000$ installed. Now im a mechanic and demand the use of this everyday, iam going to install myself save bout 2000$. If you only want to fill your own tires if off roading then would stick to cheap electric ones.
