Question about edge attitude with juce
Old Mar 2, 2009 | 10:17 PM
Lubbockguy1979's Avatar
Lubbockguy1979
I posted this but haven't gotten much in the way of a response. I have a 04 psd I am looking at buying a edge box for gauges. It is a juice with attitude. It has the thermocoulpe and is less than 2yrs old I'm getting it for $200 my question is will this work for my truck as guages if it came out of a 06-07 truck? I have a x2 and am running spartan tunes currently but am curious as to what the egts are
Old Mar 2, 2009 | 10:24 PM
natem8301's Avatar
natem8301
I wouldnt recommend switching....From all the research i've done on here everyone is comming from edge products and going to SCT Don't go in reverse
Old Mar 2, 2009 | 10:32 PM
Lubbockguy1979
I am using the sct x2 and the cheapest set of gauges that seem like they would be usable ie (edge insight $300+ or glowshift $300+) so I can save a hundred dollars get basically a edge insight which I could possibly sell at a later date and not use the edge tuning.... That way I will be using a x2 and have gauges
Old Mar 2, 2009 | 10:42 PM
natem8301's Avatar
natem8301
Sorry I misread your post sounds like a decent deal....Personally i will be going with X3 and analog gauges as soon as i can come up with the dough
Old Mar 2, 2009 | 10:48 PM
alamojimmy's Avatar
alamojimmy
If you are only wanting to use it as a guage, I don't see why it would not work. The only question I have is that if you are running the tune that you are running and don't want to use the Edge as a chip, how does the display on the Edge get it's power. I know it will fit from the 06-07 truck. Not sure how the tunes work (I personally have the same Edge chip you are looking at and love it) or if they would work if you had the edge plugged in and set on stock. Someone in here will know for sure though. Hopefully this just gives you a boost and keeps you on the front page for a bit. Good luck
Old Mar 3, 2009 | 07:32 AM
07Dually's Avatar
07Dually
This may be what you are looking for:
https://www.ford-trucks.com/forums/8...nitor-sct.html
Charlie
Old Mar 3, 2009 | 09:47 AM
WWBeast's Avatar
WWBeast
I have been using the edge juice as a monitor only, it works fine and saves me money since i do not have to go out and buy gauges.
