Sponsored by: Real Truck
coil spring identification
Old Mar 2, 2009 | 09:52 PM
bayou barataria's Avatar
bayou barataria
I would like to get the weight rating on my springs, can someone point me in the right direction? Thanks.
Old Mar 2, 2009 | 10:14 PM
jerzydiver's Avatar
jerzydiver
the spring code is located on the vehicle sticker on the foor pillar
Old Mar 2, 2009 | 10:18 PM
Furian's Avatar
Furian
You Keep What You Kill
There was a very detailed thread recently but I can't find it because the "Search" feature isn't working. I believe I was another thread in the "Tech" section that covered this as well.
Old Mar 3, 2009 | 08:25 AM
rjfetz1's Avatar
rjfetz1
Inside your drivers door will be a sticker with all the GAWR's Look at what the front spring is rated at that is what springs you have. Should be in the range of 4800lb. Depending on what your looking for there are several options available for you. Springs or leveling kit.
