High pitched whining
Old Mar 2, 2009 | 06:02 PM
eprn1n2's Avatar
eprn1n2
I have a this whining that varies according to truck speed and not engine speed. It started about two weeks ago when I went over a speed bump with a little speed. The front axle was relaced so it is not from the front. I looked under the truck and noticed a center support bearing. Do these give any problems? What else might it be?
Old Mar 2, 2009 | 07:30 PM
slowmans's Avatar
slowmans
could be the bearing or the rearend?
Old Mar 2, 2009 | 07:34 PM
eprn1n2's Avatar
eprn1n2
I'll put in on jacks and run it.
Old Mar 2, 2009 | 07:44 PM
Bustaduck's Avatar
Bustaduck
could be the center support bearing but my rear carrier bearing went out. you can feel it in the floor board under your feet . this drove me insane until I found out what it was.I finaly jack up the rear end and set on jack stand and put in drive and got under the truck and found the noise was coming from the rear end
Old Mar 2, 2009 | 08:16 PM
eprn1n2's Avatar
eprn1n2
Where is the RCB located? Did you change yours out?
Old Mar 3, 2009 | 06:30 PM
Bustaduck's Avatar
Bustaduck
in the rear end
Old Mar 3, 2009 | 06:32 PM
Bustaduck's Avatar
Bustaduck
no I had a machinc do it for me
Old Mar 3, 2009 | 06:46 PM
eprn1n2's Avatar
eprn1n2
I spoke to a transmission place today and they say it is most likely in the rear diff. This truck is killing me!
Old Mar 4, 2009 | 11:27 PM
eprn1n2's Avatar
eprn1n2
It was the Center Support Bearing. $180
