Oil Cooler Leaking
Old Mar 2, 2009 | 12:09 PM
97 HD's Avatar
97 HD
Oil Cooler Leaking
Was under the truck today and noticed oil all over my steering box, front of the drivers side leaf spring and all over the general area. Quick inspection led me to the oil cooler. I will do a more in depth inspection when it warms up a bit, but for now im thinking its the source of my leak. Questions are: anyone have the part number for the oil cooler rebuild kit? What has to be drained to remove the cooler, Engine oil, Coolant, or both? I'll do a search for a writeup, but if anyone has the link handy, it would be nice.
Old Mar 2, 2009 | 02:59 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
you need to drain your coolant and engine oil take off your drivers side fenderwell jack up your truck and take the tire off your gonna need two inner orings and two outer orings and the gaskets and it was easier for me to loosen the driver side motor mounts and jack up the motor its really pretty easy just time consuming let me know if you have any questions i just had to do that myself
Old Mar 2, 2009 | 04:45 PM
Cuda_jim's Avatar
Cuda_jim
Take a look here for the cooler o-ring repair
Oil Cooler Overhaul
