oh dear !!
Old Mar 4, 2009 | 02:29 PM
starmilt's Avatar
starmilt
May be possible it caught some air or something. I'm thinking fuel is what shut you down in the first place it would be pretty noticable if it was oil.
Old Mar 5, 2009 | 01:20 PM
crazy-tim's Avatar
crazy-tim
ok!.. so she drank another gallon of oil !!... but now it is registering full... well almost !!... and still no phantom acceleration when i started her !!... here's hoping the oil is the cure !!....thanks for all the advice people !!.... i will check the tranmission fluid over the weekend... You have to do it while the engine is running don't you ??.... well mum's said i can use the honda tommorrow for work so at least i won't be coming back on a tow truck !!!..........
Old Mar 5, 2009 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
After running straigt veggie oil, I think you need to change the fuel filter.
When you install the new filter, fill it with Diesel Kleen and run a double dose in the fuel tank.
Veggie oil and low temps are not a good combination.
Old Mar 9, 2009 | 01:21 PM
crazy-tim's Avatar
crazy-tim
well... after two days at work and 100 miles later .. i have had no problems whatsoever !!.... a big thanks to everyone for all your help and advice..... KEEP ON TRUCKING !!..... Tim
Old Mar 9, 2009 | 01:33 PM
starmilt's Avatar
starmilt
Have you checked your oil again. Make sure you are on level ground.
Old Mar 14, 2009 | 07:47 AM
crazy-tim's Avatar
crazy-tim
another 100 miles completed and still no problems !.. yes i've checked the oil again !... registers just below the " full " mark !.. once again thanks for all your help and advice...... now how do i get 40mpg !! ha ha!!..... keep on trucking !!.... Tim ( crazy) !!
EricdeToad
Feb 24, 2015 09:27 PM
mariobusalacchi
18
Aug 3, 2009 08:34 AM
FirstBronco
1978 - 1996 Big Bronco
13
Oct 20, 2005 03:57 PM
1998F250
Electrical Systems/Wiring
Mar 15, 2005 12:29 AM
