Anybody every painted?
Old Mar 1, 2009 | 11:06 PM
twister2gt's Avatar
twister2gt
I have a little under a gallon of paint i purchased a few years ago for my mustang but i never used it i just got the car painted at a body shop but i want to paint my truck is this enough or do i need more? it is a Regular cab longbed F250. I will just be painting the body will not be painting the jambs.
Old Mar 2, 2009 | 12:02 AM
deeznuts822's Avatar
deeznuts822
When u paint u have to use a reducer if i remember correctly, so what u have should be more than enough. Go to a paint shop and ask. Its been a few years since i did the body shop thing but im almost sure paint is too thick to spray without reducing. I could be wrong but?
Old Mar 2, 2009 | 12:37 AM
Biglame's Avatar
Biglame
It really depends on the paint. Some paints are designed for single coat application (U-tech, delfleet, etc.), but most require 2 wet coats. Talk to the paint shop you bought it from, they will know for sure. Just FYI, I painted my truck (extended cab, long bed) with about 3/4 of a gallon of U-Tech.
Old Mar 2, 2009 | 06:37 AM
twister2gt's Avatar
twister2gt
Its a single stage paint and you do have to reduce it
Old Mar 2, 2009 | 09:38 AM
Runboy's Avatar
Runboy
What kind of paint? Color? Prep work? Sealer?
Mike
Old Mar 2, 2009 | 10:17 AM
quicklook2's Avatar
quicklook2
painting a vehicle is not that hard, if you have the right equipment and a CLEAN place to spray in.
PREP is everything.
i find using a shop is much easier and cheaper in the long run.
