Starter Removal
Old Mar 1, 2009 | 03:42 PM
SouthernBlues's Avatar
SouthernBlues
Starter Removal
How hard is it to change the starter on a 95-F-150 with a 4.9 6 cyl.
Old Mar 1, 2009 | 04:01 PM
ottawaguy's Avatar
ottawaguy
Everyone's ability is different. However, swapping out a bad starter is not hard at all.
Gasoline Engines
1. Disconnect the negative battery cable.
2. Raise the front of the truck and install jackstands beneath the frame. Firmly apply the parking brake and place blocks in back of the rear wheels.
3. Tag and disconnect the wiring at the starter.
4. If necessary, turn the front wheels fully to the right. On some later models it will be necessary to remove the frame brace.
5. Remove the starter mounting bolts and remove the starter.
Depending on the height of the truck...you may not need to jack it up.
Hope this helps
Old Mar 1, 2009 | 04:13 PM
quicklook2's Avatar
quicklook2
i will add:
the starter is heavy, be ready for that.
get a good brand, not an autozone starter.
Old Mar 1, 2009 | 04:54 PM
1966Tbird's Avatar
1966Tbird
also make sure the starter is sealed up if you go mudding that way if you get it underwater it doesn't hurt it use permatex or equilivent
