Overdrive Indicator Light
Old Mar 1, 2009 | 03:15 PM
canuckelhead's Avatar
canuckelhead
Does anyone know how to change the bulb for the OFF light on the shifter stalk?
Not having any luck doing a search.
Old Mar 1, 2009 | 04:18 PM
swaybar's Avatar
swaybar
why will the overdrive light on the shifter lever not come on when you press the button??
is that what your talking about?
the button on the end just pops out with a little help from a pocket knife, comes out like a plug that has three little prongs, but as far as the light bulb i'm not sure if you might need a whole new shifter lever??
i just bought one a few months ago, dealer item-$50.00
Old Mar 1, 2009 | 04:26 PM
60RatRod's Avatar
60RatRod
I replaced mine from a junkyard piece, I disassembled and reassembled the unit without having to replace the whole lever.
Old Mar 1, 2009 | 04:47 PM
canuckelhead
Thanks guys,
Was just curious about that end, will try the prying now that I know it'll give Brian.
Still works fine on the shift, just like the idiot light for piece of mind.
Found the thread on lever replacement Dan, just hoping for a quicker fix.
Old Mar 1, 2009 | 05:06 PM
hammer65's Avatar
hammer65
Probably a broken wire in the shifter column. Several posts on the subject. I found mine and spliced in a new piece of wire. Works fine now. Hammer
Old Mar 1, 2009 | 05:34 PM
60RatRod's Avatar
60RatRod
If thats the case....and you have more than one wire needing spliced.....the wiring scheme is as follows:
Purple/Brown = 1
Light Blue/Tan = 2
Green/White = 3
there are pics in my gallery under tid bits folder
Old Mar 1, 2009 | 05:38 PM
Orezona's Avatar
Orezona
I haven't see it apart, but I would like to change mine to green to match my gauges. Only yellow letters in the dang cab.
Any ideas?
tjdad62
Aug 19, 2011 05:42 PM
big red ranger
1983 - 2012 Ranger & B-Series
15
Feb 20, 2011 06:29 AM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
redvet
May 28, 2002 09:40 PM
