Sponsored by: Real Truck
Head Gasket survey
Old Mar 1, 2009 | 07:52 AM
fast420a's Avatar
fast420a
Head Gasket survey
How many 6.0 powerstroke owners have had the leaking head gasket issue. At 90,000 miles my routine oil change at the dealer turned into a turbo change and head gasket replacement. I'm replacing the factory bolts with arp studs so maybe it won't happen again. Oh and my truck is completely stock.
Old Mar 1, 2009 | 08:05 AM
tex25025's Avatar
tex25025
Leaking heads on mine. I've been running stock gaskets with ARPs and no issues so far. Unless for some odd-ball reason you get defective studs, the only true variable that would bring headgasket issues back on a truck running stock gaskets and headstuds that's pushing less then 575hp would be installation error. If somewhere during the installation process things weren't done right, it'll rear it's ugly head back up. Consolation news is that you'll be able to re-use the studs though.
Old Mar 1, 2009 | 10:45 AM
GregsSD's Avatar
GregsSD
My EGR cooler, Headgaskets, heads, and turbo had to be replaced at 35k mi.
I have ARP studs in now and haven't had any more problems.
