Checking My Numbers...
Old Feb 28, 2009 | 11:11 PM
EastTexasTruck's Avatar
EastTexasTruck
Question Checking My Numbers...
As some of you know I'm seriously considering a swap from my C6 to a ZF5. I have 4.10's and want better mileage and more shift control.
Using the calculator here I used 3000 RPM with 31" tires to get 70.4 MPH. Since the C6 is 1:1 and the ZF5 is either .77 or .76:1 depending on whether it's close or wide ratio I took .23 (the difference between 1 and .77) and multiplied it X 3000 RPM which equals 655.5. I then subtracted 655.5 from 3000 to get 2310 RPM at 70.4 MPH. I just want to verify that this is the right result. Very good if it is. Should improve mileage a good bit. I know that some of y'all are good with the numbers and just want a second, or third opinion.
Thanks again. I always know I can come here and get good answers.
Old Feb 28, 2009 | 11:15 PM
RCrawler's Avatar
RCrawler
There are several gearing calculators on the net. Here's one that I use:
4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
i came up with 2364 rpm at 70 with your combination
Jason
Old Feb 28, 2009 | 11:39 PM
EastTexasTruck
Thanks RC. I like that calculator too. I wondered why our numbers were off a bit and discovered that when I posted I put in the wrong tire size. 34" instead of 31. Looks like I was on the right track, but I'm no math wizard and it would be a very bad thing to get it together and not have what I expected.
Old Mar 1, 2009 | 03:09 AM
fonefiddy's Avatar
fonefiddy
Do You actually pull anything with Your truck? If not, consider going with 3.55's
I swapped My 4.10 to 3.55 last summer. I gained a 1/4 tank of fuel on a 200 mile trip. And can actually use 1st gear.
Old Mar 1, 2009 | 01:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Even if you do pull something, 3.55 gears are not that bad.
You might be using lower transmission gears than you are now, but the higher gears are stilll there when you need them.
The only downside to higher axle gears is the extra wear on the U joints.
Old Mar 1, 2009 | 05:24 PM
EastTexasTruck
Right now I don't pull anything with it but I am considering getting either a bumper pull camping trailer or a decent size slide in camper for it. My work will require me to do some traveling to places I might need to bring my own house.
I may even consider a 5th wheel trailer if I can find a deal.
Old Mar 1, 2009 | 06:44 PM
whiteguy589's Avatar
whiteguy589
I have the zf5 with 4.10's and I am doing 24-2500 at 70ish mph..... I am running 235/85/16's which i believe are about 31" tall
Old Mar 1, 2009 | 10:45 PM
jmmartin's Avatar
jmmartin
Hey easttex, granted mine is the t-19 i have 3.55 on mine and routeinly pull a l3400 kubota with several implaments, and last weekend i pulled a 35' 5th wheel with mine. the only problem i had with the 5th wheel was that the camper had been sitting for 6 years, had sunk about a foot and had 4 flats. once i got it yanked out and the tires aired up, it at 10-12k pulled easier than the kubota at about 4k. And i think the hills next door to you here in woodville are as bad as anywhere in east texas, and my old truck handles them well.
