rust spots??
Old Sep 27, 2002 | 02:41 PM
76_F150_390's Avatar
76_F150_390
rust spots??
the doors on my 76' have those nasty bubbled out rust spots on them, and I am wondering what the best way to get rid of them is. I have tried to sand them, but it hasn't worked to well...and it takes a long time.
I was thinking of spraying over them with a filler primer with many coats, sanding them in between.
thanks for any help
Old Sep 28, 2002 | 08:44 PM
dickson98's Avatar
dickson98
rust spots??
The best way would be to cut out the rusted spot and use a fiberglass repair kit unless, the damage is extensive. Then you should probably just replace the door skin. Just make sure that if you decide to patch it use a rust arresting chemical on it. I'm in the process of removing all the rust from my 82 F100 some will be patched and some panels will be replaced. Good luck and have fun.
Steve
Old Sep 29, 2002 | 05:44 PM
groundrat's Avatar
groundrat
rust spots??
