How do I?
Old Sep 15, 2002 | 07:32 PM
groundrat's Avatar
groundrat
How do I?
I have a 1994 F150 xtra cab short bed. When I bought the truck the bed was dented a little. The part of the bed right next to the cab is dented in to almost touch the cab. How do I go about pulling this out? I am getting a cap and it wont fit correctly the way it is. I will post a pic when I get home. Thanks in advance.
Bill
Old Sep 16, 2002 | 07:17 AM
Dualiedo's Avatar
Dualiedo
How do I?
you should just be able to pull it out with hands. If its what I'm thinking, it is from something like a three or four wheeler being rode up in the truck.
Old Sep 16, 2002 | 02:03 PM
Rosati's Avatar
Rosati
How do I?
This Is what I did to an old Chevy:
1. drop the tailgate
2. place a 6ft 4x4 on the tailgate
3. hook up a come-along to the 4x4 and place a couple layers of rags between the wood and the steel.
4. drill a hole in the upper lip of the bed behind the cab as close to the deformity as possible
5. insert an eye bolt (1/4"x4") with a couple of washers on the cab side
6. hook up the come-along and start cranking.
The holes in the bed can be filled with silicon or welded shut and the 4x4 will not dent the rear of the bed.
Old Sep 29, 2002 | 05:44 PM
groundrat's Avatar
groundrat
How do I?
Thanks for the tips. I will try the come a long trick out and see if it works. Thanks.
Bill
Old Sep 29, 2002 | 06:25 PM
HotWhlz85's Avatar
HotWhlz85
How do I?
