primer before or after
Old Sep 28, 2002 | 03:26 PM
mtford1's Avatar
mtford1
Hi. I am doing some body work to the inners of my trucks cab. Around the door post and drip rails i stripped of the paint and blasted all the rust off. On the bottom of the door post i want to just smooth out the imperfections with some polyester putty. But I was wondering should I use PPG epoxy primer on these areas first, then apply the poly. and finish with high build primer and paint. Or should i just put down the poly, high build and paint. There wasnt much for rust in these areas i just want it to look clean and last a long time. I got alot of pics to add in my gallery, and i will do so in the next couple weeks. thanks for your help.
mike
Old Sep 28, 2002 | 04:58 PM
welder man's Avatar
welder man
You may want to use acidwash to etch it if its
down to the raw steel before you put putty or
primer on it .
If it still has paint on it just sand it with
320 then use putty primer paint.
hope I could help some.
good luck
welder man
Old Sep 29, 2002 | 08:04 PM
Fordzlla's Avatar
Fordzlla
Use the epoxy primer before the filler.
I've had great luck with ppg epoxy primer
Old Sep 29, 2002 | 08:22 PM
mtford1's Avatar
mtford1
Thanks guys. I think im going to spray the PPG primer before i lay down any polyester.
mike
Old Sep 29, 2002 | 09:59 PM
rustydog628's Avatar
rustydog628
