4WD issue
Old Feb 28, 2009 | 10:31 AM
ggwash21's Avatar
ggwash21
Question 4WD issue
Ok so i had 4wd 2 days ago when we got snow, and yesterday i noticed that the 2 double vac lines were disconnected on the front hubs so i plugged them back in and now today i hear the 4wd engaged at T-case and 4WD light comes on but no go on front tires??????????
Old Feb 28, 2009 | 11:04 AM
ggwash21's Avatar
ggwash21
So i go out there and pull that double vac line off and hear air release and then plug it back in and mess with the 4WD switch and still nothing. ?
Old Feb 28, 2009 | 03:03 PM
mattd17's Avatar
mattd17
did you post this same issue on another forum? i sent a reply there....
Old Feb 28, 2009 | 05:39 PM
Ford-man22's Avatar
Ford-man22
Sounds like your hubs maybe stripped out. That same prob happend to me on a 98 ranger 4wd. Everything else worked but the the front tires wouldn't turn. You could try to replace the vacuum pump and see if that works but if you have air down at those hubs then it's prob the hubs themselves. Hope this get's ya on the right track anyway.
ggwash21's Avatar
ggwash21
sure did thanks
Off to the dealer monday thank god for ESP
Old Feb 28, 2009 | 06:25 PM
BluByu1986's Avatar
BluByu1986
Take the vacuum lines off both hubs and take off the connection on the solenoid. Then take some compressed air and blow out the lines. Then re-attach all lines and go for a drive and engage 4WD.
This same thing happened on my truck, except only 1 line came off at the hub and plugged up the system with all kinds of crap. Once I blew out the lines, everything was like new.
Good luck,
