Next stupid question...
Old Mar 1, 2009 | 08:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by Lazy K
Funny you should say that. I have a `87 F250 6.9 C6 with RABS and the sensor mounted on top of the rear diff.
How to figure?
don't really know.
none of the 6 88 to 91 diesels with 10 1/4 rears i had when i was still in business had any sensors at all on the diff. the sensors were mounted into the rear of the BW 1356 transfer case at the speedometer pickup.
Old Mar 1, 2009 | 09:42 AM
JesterPgh's Avatar
JesterPgh
The RABS control module is on top of the transmission tunnel and behind the ash tray grouped with the cruise ECM. I don`t know if it has its own ground or not.
If you look under the dash either near the parking brake pedal or behind the glove box you should find a black wire with an orange stripe with a connector on it. This is the RABS diagnostic connector. With the ABS light on if you momentarily ground this wire the ABS light should blink out a fault code. You could try that.
The sure way to bypass the RABS is to get a short length of brake pipe and use it to bypass the RABS valve body on the left side frame rail.
Hope this helps.
Thank you very much!
beeser
Oct 11, 2013 10:07 AM
mikulskn
Jun 26, 2013 11:23 PM
brkncly
6.4L Power Stroke Diesel
Sep 15, 2012 09:47 AM
redman84
30
Jul 2, 2012 07:01 PM
RobbyMartin
1997 - 2003 F150
Sep 5, 2010 10:54 PM
