oil leak oil on top of manifold
sure its oil not the drain plug on your fuel bowl? the common leak is there where the Yellow handle is for the fuel drain. those leaks are starting in the Valey. clean the truck up. you can use Simple Green and just wash the Motor up.
than you can start it up and check for leaks. you can use shop towels and dry the valley up. this will make looking for leak hell of the diference.
Welcome to FTE
Welcome to FTE
