carbs
Old Feb 27, 2009 | 04:37 PM
colorsink's Avatar
colorsink
carbs
i have a 1980 f250 with a 351 m and a 2barrel carb and a 1985 f150 302 with a 2barrel can i swap these carbs between vehicles thanx
Old Feb 27, 2009 | 09:31 PM
LARIAT 85's Avatar
LARIAT 85
Assuming both carburetors are original, NO, you CANNOT swap the two carbs without other modifications. The 1980 used a conventional carburetor, while the 1985 302model used a "Feedback" (computer controlled) carburetor.
Two COMPLETELY DIFFERENT animals.
Old Feb 28, 2009 | 12:01 PM
colorsink's Avatar
colorsink
ok so what would i have to do to swap them would i have two swap distributors too or would the one from the 351m even work on the 5.0
Old Feb 28, 2009 | 06:06 PM
LARIAT 85's Avatar
LARIAT 85
Well no, you cannot use a 302 distributor in a 351 engine.
The feedback carburetor uses a different, computer controlled distributor and ignition system than a coventional setup.
Which truck and engine are you going to USE? Between the two trucks, which one do you want to end up with? We can start there.
Old Feb 28, 2009 | 06:45 PM
Franklin2's Avatar
Franklin2
There is also a venturi size number on the side of the carb somewhere. Maybe someone knows where it is, I am not sure, but it sizes the carb and you will want that to be the same. For instance, I think a valid venture size was 1.08. A 302 might have had a smaller venturi than a 351 engine.
ericford1984
Dec 5, 2011 08:47 PM
80 f-150
Sep 5, 2011 11:47 PM
Lumpy78
May 4, 2010 11:25 PM
blazer350
May 18, 2008 07:11 AM
83f100ss
Jan 19, 2004 12:22 AM
