undercoat removal?
Old Oct 29, 2002 | 01:53 PM
supercab78's Avatar
supercab78
undercoat removal?
What can I use to remove Zeibart undercoating from a previously painted areas? I'm changing colors on my old truck & undercoating overspray is in areas that I need to edge in. thanks Jeff
Old Oct 30, 2002 | 03:04 PM
vettehauler's Avatar
vettehauler
undercoat removal?
If its just in an area you are going to blend into (like along the floor pan) then I would just sand it off. If that doesnt work (because of danger of damaging earlier repairs) then I would grab a chemical stripper like EZ STrip, or something of that nature and use a putty knife of even a razor blace to clean it up real nice. If you use a chemical stripper, make sure you wash the area real good with warm water, and Baking soda to neutralize so you dont end up with bubbling paint later.
If that doesnt do the trick, pm me and I will be glad to offer more tips that might.
Drew
Old Oct 30, 2002 | 06:46 PM
RBrendel's Avatar
RBrendel
undercoat removal?
i just undercoated my truck, look at that can of undercoat and it tells you exactly what to get to take it off.
Old Oct 30, 2002 | 07:33 PM
rogerpc's Avatar
rogerpc
undercoat removal?
