Leaking radiator fluid?
Old Feb 27, 2009 | 10:37 AM
ArtsBest's Avatar
ArtsBest
A small amount on the floor every morning. I don't believe any hose is damaged nor the radiator. What else could it be? Can the fluid leak out of the block due to gasket wear? Thanks.
Old Feb 28, 2009 | 07:20 AM
Lazy K's Avatar
Lazy K
One common place for a leak is the little drain hole in the water pump housing just behind the fan. If there is a leak there the coolant will normally run down the front of the engine and drip from there on to the floor.
Old Feb 28, 2009 | 01:56 PM
oaskills's Avatar
oaskills
Check the heater core make sure it does not have any pinhole leaks
