manuel tran question
Old Feb 27, 2009 | 09:22 AM
donaldm's Avatar
donaldm
2000 ranger 4 cyl, 175000 miles Manuel trans. Question . . . two days ago I get a strange sound from around the tran area, it sounds like small pee size rocks falling on a tin roof. I hear it when I begin to accellerate in 1st or 2nd gear or with clutch in as I begin to pull shifter into gear but not in nutrel not with clutch in or out, not in higher speeds, My first thought was throw out bearing but it doesent do it when i press the clutch in, so im thinking maybe a bearing in the trans?? anybody experinced this issue? thanks
Old Feb 27, 2009 | 10:14 AM
Pablo-UA's Avatar
Pablo-UA
try to change fluid first. usually this sound appeares when gears are worn a bit ore play inside tranny, bearings.... difficult to understand what is wrong with tranny on truck. usually I can see problems when tranny is disassemblied
Old Feb 27, 2009 | 11:02 AM
donaldm's Avatar
donaldm
I dont have the owners manule what trans fluid does it call for?
Old Feb 27, 2009 | 11:19 AM
Pablo-UA's Avatar
Pablo-UA
look for M5OD manual... i have some pages...
I need e-mail addr to post them
Old Feb 27, 2009 | 03:30 PM
michigan66's Avatar
michigan66
The M5OD transmission uses Mercon Automatic Transmission Fluid (ATF).
Old Feb 28, 2009 | 05:06 AM
wendell borror's Avatar
wendell borror
It still could be the throw out bearing, they don't allways play by one set of rules when they go bad. The sound you describ sure sounds like a TO bearing.
Workinman94
Feb 5, 2017 12:57 PM
Tanner Berdahl
Sep 2, 2016 12:49 PM
53fordman1
Jul 28, 2016 12:01 AM
53fordman1
Jul 26, 2016 12:18 AM
tranthac1
Apr 4, 2003 06:10 AM
