need help with tranfer case swape
Old Feb 26, 2009 | 08:56 PM
leo1980's Avatar
leo1980
I have a 1988 ford 150 want to put a 1979 transfer case in it I know I have to modify the adapter but will the drive shaft work out of the 79
Old Feb 26, 2009 | 10:51 PM
archangel's Avatar
archangel
A transfer case swipe?
Where do you plan on swiping the transfer case from?
You might have less trouble just purchasing one honestly.
Old Feb 27, 2009 | 07:07 AM
stangbanger's Avatar
stangbanger
LMAO everyones a smarta**
Old Feb 27, 2009 | 11:03 AM
alxsnmr's Avatar
alxsnmr
I thought that stouter u-joints were employed in the half tons after 79. Easy way to check is to see if the U-joints interchange between your truck and the 79 at the axle. Driveshaft mods may be necessary to get the new case in place. The NP-205 may require an additional frame mount on the drivers side for added support where the BW-1356 only mounted to the transfer case.
Old Feb 27, 2009 | 11:30 AM
mando jake's Avatar
mando jake
If you have a 4x4 tranny already, it should be a bolt-on. With a 205 you will prolly have to notch out the tailhousing on the tranny for the shift rails on the 205, and you will need to make brackets to support it on the sides. To my knowledge all ford output shafts were the same diameter and spline count, but some (broncos?) had shorter length shafts/tail housings. You might try consulting the 73-79 forum, a very knowledgeable group.
Old Mar 2, 2009 | 08:52 AM
alxsnmr's Avatar
alxsnmr
The 205 in my 78 only had a yoke output from the case and not the slip joints found on the newer BW transfer cases. The driveshaft was a two piece with the slip joint in the drive shaft not the case.
Old Mar 2, 2009 | 12:42 PM
mando jake's Avatar
mando jake
yeah I always just get the driveshaft with the case... cut and splice as needed.
