Weak motor problem
Old Feb 26, 2009 | 08:04 PM
Gottalovethemf100s's Avatar
Gottalovethemf100s
Weak motor problem
Im not sure what size engine I have but i think its a 351W(just got the truck). Anyway I live in Boone, NC in the mountains and when i try to climb the hill to my house the truck bogs down real low even in 1st gear. What could this be? Also it needs a patch in the exhaust but not a big hole.
Old Feb 26, 2009 | 10:35 PM
Holiver31's Avatar
Holiver31
could be alot of things but if you havent rebuilt or bought a new carb thats a good idea to do even if its not the problem
Old Feb 26, 2009 | 10:47 PM
Gottalovethemf100s
The motor is rebuilt and has newer 4bbl holley carb
Old Feb 26, 2009 | 11:26 PM
fmc400's Avatar
fmc400
MSEE
Why is it a good idea to spend $300 on a new carburetor "even if it's not the problem?"
Check your base timing with a timing light, and verify the vacuum advance on the distributor is functioning.
Old Feb 27, 2009 | 07:46 AM
Holiver31's Avatar
Holiver31
he did not mention that it was a fresh rebuildt motor nor did he metion it has a brand new carb,,i had the same problem so i rebuilt my carb for $45 and bam,,,engine ran fine,,i was just saying that if it still had the stock carb its usually a good idea to rebuild them
Old Feb 27, 2009 | 09:22 PM
Gottalovethemf100s
Thanks Holiver, Ill do that
