Valve cover gaskets...
Old Feb 26, 2009 | 03:45 PM
ghunt's Avatar
ghunt
How involved of a job is changing out valve cover gaskets on these engines?
Mine appear to be pissing oil like a drunk irishman and it's running all down the sides of the engine and dripping on the ground.
Old Feb 26, 2009 | 04:05 PM
Wookie35's Avatar
Wookie35
You may want to check how tight they are before going through the trouble. In my headgasket tear down I found my to be less than hand tight! Mine had been leaking for some time and I wish I had checked long ago, might not have had to buy so much oil.
Old Feb 26, 2009 | 06:09 PM
bad12jr's Avatar
bad12jr
Definently check them mine were loose and they are again. If u can pull the bolts one by one and put a little locktight on them. I need to do it too its just been to cold.
Old Feb 26, 2009 | 08:17 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Not to bad of a job, passenger side takes a bit longer because of the heater box and fuel filter makeing a couple of bolts more fun to remove and replace.
Old Mar 2, 2009 | 02:48 PM
ghunt's Avatar
ghunt
I didn't think loosening bolts was a big problem, I'll definitely have to check that first off.
Old Mar 2, 2009 | 10:57 PM
Dave Sponaugle
One bolt under the fuel filter is a pain, two bolts back at the firewall are a pain on the passenger side.
Old Mar 3, 2009 | 08:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
the gaskets on my 88 are shot. but i am waiting untill i pull the cab to put the new one on to do the VC gaskets. then i will not have the ac box in my way.
Old Mar 3, 2009 | 10:21 AM
165's Avatar
165
Make sure it's not your turbo oil supply line leaking...just went through this same thing with our turbo '94. Thought valve cover gaskets were leaking (they were a little loose), but they weren't leaking. If it is the turbo oil line, you can't fix it by tightening it-replace the fittings at the ends. Mine was leaking @ the block end-I cut off the little flare on the end of the tube and used a push-in hose fitting instead (like the airlines on a big truck use).
Old Mar 3, 2009 | 10:26 AM
Franklin2's Avatar
Franklin2
On most engines I have messed with, it's not the bolts coming loose, it's the gasket shrinking making the bolts loose. A older gasket shouldn't do it very much, but a new gasket will need to be re-tightened after a couple of weeks, and then after a few months.
Old Mar 3, 2009 | 12:18 PM
ghunt's Avatar
ghunt
Nah the feed line isn't leaking. I have a -6 AN line on my truck. It looks like it seeps a little at the turbo end but it's not leaking enough for this.
The oil I have is running down from the valve covers, down the sides of the engine and dripping off the pan and such. Every now and then I can smell burned oil through the heater (I assume from it getting on the exhaust manifold when they get hot)
