5.4 liter preignition problem.
Old Feb 25, 2009 | 05:20 PM
mcoggins1's Avatar
mcoggins1
I need some help with a preignition problem. I have a 98 expy with a 5.4l. It has 166k miles on it. I am getting a lot of pinging under load until it is warmed up. After that I get some when it shifts into a higher gear but only for a very short time (2 or 3 pings then its gone) I'm not getting any codes. I have cleaned the MAS which helped quite a bit with the pinging on the shifts but no change when cold. I have replaced the EGR Valve and made sure the ports to the throttle body are not clogged with Carbon (No Change). I have also tried running sea foam trough the vacuum tube into the back of the throttle body (No Change). I have seen in other post that the DTFE sensor may cause problems with the EGR system but this normally throughs a code and causes idle problems.
What else should I look at? The plugs where last changed at just over 100,000 miles.
Old Feb 25, 2009 | 07:40 PM
LxMan1's Avatar
LxMan1
Many 98 F150's had too much timing and required a PCM reflash.
Have you checked the fuel pressure? A partially clogged fuel filter can cause a lean condition. It needs to be driven with a real time data logger to watch the fuel and timing trims to see if either is out of range.
Old Feb 25, 2009 | 08:37 PM
mcoggins1's Avatar
mcoggins1
Thanks
I forgot to mention that I just changed the fuel filter 2 weeks ago.
It seems that the pinging is always coming from the left (Driver) side of the engine. Is there any chance I just need to change the plugs?
Old Feb 26, 2009 | 10:37 AM
whimsey's Avatar
whimsey
Originally Posted by mcoggins1
Thanks
"True" pinging with a cold engine is most unusual. With your year engine and cold "pinging" I'd be looking at a plug getting ready to blow out of the head. Might be a good time to check them or change them. Use antiseize and a torque wrench when re-installing them. If you had the newer PI heads then possibly your rear exhaust valves are sticking. But they usually cause an "exhaust manifold ticking leak sound".
Whimsey
Old Feb 26, 2009 | 06:30 PM
LxMan1's Avatar
LxMan1
I too suspect a couple of broken exhaust manifolds studs.
I would double check the spark plugs to make sure none are loose or you could blow one out of the head and that is bad news. But, I would suspect the exhaust is leaking at the head. Pretty common.
