clearing codes
Old Feb 25, 2009 | 03:39 PM
frankyford's Avatar
frankyford
clearing codes
I'm trying to reset the codes for my 95 F-150 302 auto. Does anyone know how to do this, besides taking off the negative battery cable. Thanks
Old Feb 25, 2009 | 04:02 PM
str8dogg's Avatar
str8dogg
That is the easiest way. The other way would be to run the codes with a scanner and delete, or whatever way the reader removes the codes after correction.
Old Feb 25, 2009 | 04:29 PM
Conanski's Avatar
Conanski
Find the STI wire in the EEC test harness and ground it.
Turn the key to run and let the codes begin to flash on the check engine light.
Remove the ground wire and the codes will be erased.
