Question about oil filter
Old Feb 25, 2009 | 10:01 AM
mike in nj's Avatar
mike in nj
1995 ford f250 7.3l powerstroke
So I removed the oil filter this morning and a spring and small piece of metal about the size of a dime jumped out. What is this?
Old Feb 25, 2009 | 11:24 AM
Neal 97 250's Avatar
Neal 97 250
Look Here:
https://www.ford-trucks.com/forums/4...r-housing.html
It will have all of your questions answered.
P.S. Welcome to FTE
Old Feb 25, 2009 | 01:43 PM
kawa's Avatar
kawa
If the relief valve port in the filter assembly is UN-damaged then I would think that a "Wafer" could be made from a thin, sturdy piece of material such as plastic, phenolic, etc as long as it is impervious to oils.
It is a necessary part of the oil system and if push comes to shove then the replacement of the entire filter housing assembly is your next step.
This thread sure makes one wonder how many other defective oil relief valves may be out there as I for one have never even looked nor did I know that it was even there. I will check mine at the next oil change.
Rog
Old Feb 25, 2009 | 04:07 PM
Mike8623's Avatar
Mike8623
Mine came out last oil change.......it didn't have the C-clip but was staked in three places.............I was really worried............put it all back together and restaked it back in...........but added a few more stake places............I'll find out if it is holding up next time I change the oil.......it really scared me at first.
But this site took care of me.
Old Feb 25, 2009 | 04:21 PM
powrstrkr's Avatar
powrstrkr
Thanks for that link Neil! It has some good info on the bypass valve. If the spring is too weak will the oil bypass the filter even if it is not clogged?
Old Feb 25, 2009 | 04:56 PM
mike in nj's Avatar
mike in nj
I lost the washer and c clip. Do you know what size clip? This is my first time on this site(my brother recommended it) and it's been a big help. Thank you all and thank you Neal.
Old Feb 26, 2009 | 05:54 AM
Neal 97 250
You are welcome Mike and Chris. And once again welcome Mike. There is plenty of knowledge here. Stick around and post often, remember there is no dumb question.
