Changing a flywheel?
Old Feb 24, 2009 | 10:23 PM
anthoma's Avatar
anthoma
Exclamation Changing a flywheel?
So the fly wheel is missing some teeth and needs to be changed on my moms 2000 Expedition. Could anyone tell me what all I need to do to change it? I know its a lot of work and its gonna be tough but I need to know! Thanks!
Old Feb 25, 2009 | 10:53 AM
skabbott's Avatar
skabbott
You will need to drop the tranny to get acces to the fly wheel. Which means removing the drive shaft, starter motor, any linkages, and wires. I am guessing this is a automatic, so there will be a torque conveter bolted up to the fly wheel or flex plate for automatics. The torque converter will contain tranny fluid so this can get messy as you take it off. The fly wheel will not be a solid fly wheel like you would find on a manual transmission which uses this as the clutch friction surface. There is probably 5 to 6 bolts that hold the flywheel on. I believe they recommend changing the mounting bolts to make sure they are not prestressed.
Using a floor jack with a transmission adapter will make it a lot easier to getting the tranny in and out. Harborfreight sells them for about $40, if you already have a floor jack. Make sure you do this safey- us jack stands or wheel ramps to support the car not jacks.
Old Feb 25, 2009 | 02:02 PM
anthoma's Avatar
anthoma
thank you so much for the help...i will be sure to let my boyfriend know because he is the one changing it out! will keep you updated on how it goes!
Old Feb 25, 2009 | 02:16 PM
alloro's Avatar
alloro
You left out the part of having to remove the transfer case before removing the tranny.
Old Feb 25, 2009 | 09:27 PM
MisterCMK's Avatar
MisterCMK
Slide the tranny back enough to get a wrench in there and remove the flex plate. No reason to completely remove the transmission.
Old Feb 26, 2009 | 07:19 AM
alloro's Avatar
alloro
If it were me I would pull the engine up and forward a few inches. That might be less work than pulling the t-case and tranny.
Old Feb 26, 2009 | 07:27 AM
MisterCMK's Avatar
MisterCMK
uh, about that...
Moving the engine forward is a huge pain in the keister. A tranny jack will make quick work of removing the transfer case and then simply sliding the transmission back. If you are going to pull the engine up and forward there is a HECK of a lot of stuff that needs to be removed/disconnected.
Old Feb 26, 2009 | 11:37 AM
alloro's Avatar
alloro
The big PITA in removing the t-case is having to unload the torsion bar to remove the torsion bar mount. Sometimes that doesn't go too well.
Maybe the exhaust and the fan have to be disconnected, but most everything else seems to have enough slack to allow for the engine to move a few inches. He could always unbolt the motor mounts from the block so that the engine can be slid forward without having to lift it much.
caere
6.7L Power Stroke Diesel
Aug 12, 2014 06:40 AM
LRSTony
Feb 21, 2014 01:18 PM
Yougotthehit
13
Jan 20, 2013 11:53 AM
ToolTime
Apr 23, 2009 11:21 PM
murph89
Apr 8, 2009 10:30 AM
